smartports doesnt update switchport info?
Messy
is it just me or do ports configured with smartport not update their vlan etc info on the main switchport page?
I am just playing around with implementing them on a test site and didn't think it was working until I drilled down into the port details to realize the settings had actually changed.
Messy
seems like its known about, unclear if they intend to do anything about it or when 😛
cheers
2 Replies 2
Maybe this will help you.
Solved: Re: Switchports display shows incorrect VLAN when using port profiles - The Meraki Community
Solved: SmartPorts and Automations - Testing and Learning - The Meraki Community
SmartPorts - Cisco Meraki Documentation
Messy
cheers
