We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 27.
I want to put a Switch MS390 with advanced license in the network core and MS 210 in access, I'm asking if this solution will work without any problem.
thank you.
Solved! Go to solution.
I'd avoid the MS390 altogether. there are numerous posts on this forum as to why. I'd go with an MS355 model versus an MS390
@kima25 : select the device depends upon the requirement in the core
https://meraki.cisco.com/product-collateral/ms-family-datasheet/?file
