Unable to get local issuer certificate - Cloud Monitoring for Catalyst tool
Hoang2
Just browsing
Hello Buddies,
I try to onboard some our Cisco switch C9300 to Meraki dashboard for monitoring project.
I have downloaded and installed "Cloud Monitoring for Catalyst" tool, but I got the error "Unable to get local issuer certificate" when I try to open the application on my windows 10 pc.
I tried to install it on others PC but no luck.
Is there anyone has experience on this?
2 Replies 2
sthanhlam
This looks to be an issue with the PC/connection you are using. Try the below steps:
(1) Try a wifi hotspot or a different network.
(2) Try a completely different PC
xbrugne
FYI, a customer faced the same issue and the problem was his ZScaler endpoint agent blocking the traffic.
