Unable to fetch configuration This device is unable to fetch its configuration from the Merak
rajivdaniel
This device is unable to fetch its configuration from the Meraki cloud on MS 210 and MS 225 48 The current firmware is MS 16.7 which was upgraded due to false notification alerts that Switch is offline.
Has anyone had this issue and got this fixed. I have case open with Cisco, but no response yet.
2 Replies 2
Maybe it will help you.
Solved: Unable to fetch configuration - The Meraki Community
Unable to fetch configuration - Unresolved software bug - The Meraki Community
These nearly always require support to fix.  Try opening a case.
