Trunk mode - Allowed vlan should include native as well?
Captain
Dear All,
When setting vlans on a switch port in trunk mode
do i need as well to include the native vlan on the allowed vlans?
Cheers!
KarstenI
Yes, that is also needed.
9 Replies 9
Pulkit_Mittal
while you don’t have to explicitly include the native VLAN in the allowed VLAN list, it’s beneficial to follow best practices by tagging the native VLAN and excluding it from the explicit allowed VLANs.
If you find this helpful, please leave your kudos and accept the solution.
Is this from chatgpt?
Captain
I used chatgpt for the same question before posting here and had a similar reply as posted by pulkit.
However, after experimenting noticed that if i do not add the native vlan in allowed tagged then it will not forward traffic. that is why i have posted here my question.
KarstenI
So, you found out on your own before ... 😉
I think it gets general info from internet and mix it with cisco catalyst info.
I would also not recommend removing native vlan with meraki switches as stp runs on the native vlan
Hi together,
I had the same question right now and my traffic can reach the native vlan on the other side when not including it in the allowed vlan list.
Did this change?
KarstenI
Which version and which platform?
I forgot to update my comment. It did not work for my native vlan. Had to add it too. It was a mistake from my side.
KarstenI
