Hi all,
I need an advice about applying Group Policy by Radius Response message
In MS switch I have one port configured to authenticate devices using Radius server.
Then I made a custom Group Policy with bandwidth sharping and when device connects to the network and the switch asks Radius server for approval I return the Access-Accept with the Filter-Id attribute set to the name of that custom group policy.
The device gets access to the network but in its statistics I see that it has Device Policy still set to Normal.
If I change it manually from the UI, then it apply it and the device gets the bandwidth as defined in the group policy.
But whatever I do I cannot force it to do the same using the Radius response.
I feel like I am missing something, but cannot catch it.
Thanks.
