This device is using a DHCP IP address from VLAN 7 instead of using configured VLAN 1.
watdee
I have a switch on a test network and specifically set it up without VLAN 1 so it is getting it's dhcp and connection to the meraki cloud on vlan 7 which is what I wanted.  Seems to be working fine except for the orange icon and warning.  I didn't have a reason to have vlan 1 traffic on this switch.  Is this a problem and is there a way to get the icon green or should I just ignore the warning?
antonis_sp
antonis_sp
You will also need to change the vlan on the switch info page to 7.
https://documentation.meraki.com/MR/Monitoring_and_Reporting/Understanding_and_Configuring_Managemen...
watdee
Even though it doesn't need to be tagged? The port was set to native vlan 7 and the uplink switch port was configured the same.
Its just a management/ alerting  setting. You can set it at the switch settings
