This device is using a DHCP IP address from VLAN 11 instead of using configured VLAN 1
Hameed
Access switch status showing "This device is using a DHCP IP address from VLAN 11 instead of using configured VLAN 1" and when I check the core switch, I found the "STP discarding packets from this port" message. Recently we did not make any changes and how to resolve it. Please help. Thank you
3 REPLIES 3
Roger_Beurskens
First try to solve your STP issue and/or check if the active uplink port has alle the vlans it needs so the switch can reach it's normal management vlan.
@Roger_Beurskens Thank you very much for your reply. Some IP phones created the issue and now it is resolved. Thank you
Hameed, what was the issue with the IP Phone? I am having similar issues.
-Rajiv
