Target firmware version not available under firmware upgrade
himanshu29
As we all know the latest stable release candidate for switches is MS12.28.1 ,but i would like to upgrade to 12.33 which is not showing while scheduling the upgrade
For 12.28.1 there is new bug for MS 120 switches , that printer IP gets changed when ever switch reboots .
Meraki TAC suggested to upgrade to 12.33 , but its not showing under firmware upgrade
Accepted Solutions
Re: Target firmware version not available under firmware upgrade
@himanshu29 12.33 was replaced by 14.22 as the stable release candidate.  14.22 is now a pretty good release (we run all our switches on 14.x).
8 REPLIES 8
Inderdeep
@himanshu29 : check out firmware upgrade as network admin in below link
https://documentation.meraki.com/General_Administration/Firmware_Upgrades/Managing_Firmware_Upgrades
Regards
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
himanshu29
the issue is 12.33 for MS switches is not appearing as next upgrade for me
i have access to all the org
Inderdeep
@himanshu29 : Can you go to  Organization --> Firmware upgrade and select Switch first and then click on the Schedule upgrade and check what Target upgrade is available for your switch ?
Regards
Inderdeep Singh
himanshu29
not appearing the desired 12.33 version
Inderdeep
You need to talk with Meraki Support and they will arrange for you on your dashboard !
Regards
Inderdeep Singh
himanshu29
they havent done yet , we have to wait for 12.33 to be enabled for our org
himanshu29
Meraki support said same , but we have 500 + MS 120 . But we can give it a try with few switches .
