Switches not showing up properly in dashboard
For the last week or so, when you go to the switches/switches page in the dashboard the firmware that the switches are running has not initially been displayed.  Now the whole table is empty and it doesn't seem to come back.  See below:
I've tried Edge in Windows and Chrome on Android.  Anyone else having this problem?
It seems to be fixed now (for me on n184 at least) though the display issue @RaphaelL highlighted above persists
8 Replies 8
Actually I have found (at least on the mobile) that you can go into one switch and then back to the list to get it fully populated.  Still annoying though 😡
Same here, but after clicking on device status and then back to the switch list, It worked as expected.
BlakeRichardson
Working fine for me, maybe corrupt browser cache....
I'd love to think that @BlakeRichardson , but not sure that my phone and PC share a cache... 😉
Also happens on two Meraki nodes, though both are signed up to the new interface (which I think is the issue).
BlakeRichardson
Ah good point i'm using the OG interface.
RaphaelL
Also , If you mouse over the 'connectivity' , you might not be able to see much ... :
Half of the box is hidden
T-Infra4crates
I have the same experience, when i go to the "old experience" i see there it is populated and then go back to the new it is populated. I guess there is a slight issue with the new view.
Thijs van Yperen
