Switch Stack and EtherChannel
TacoTuesday
We have four Meraki MS350 switches, said A, B, C, D.
I would like to stack A, B together, then C, D together. After that, I would like to create a EtherChannel between two stacks.
My solution is as follows, is that possible for the EtherChannel on the two different physical switches like VPC? Or I have to create the EtherChannel on the same physical switch for stacking
    A Port 49 <--> C Port 49
    B Port 49 <--> D Port 49
Thanks!
RaphaelL
Not sure to understand your question but
will work since A,B are on the same stack and C,D on the same stack.
vPC is only needed when the hardware is not stacked or configured in a VSS mode.
If your goal is to plug a device into stack A,B and stack C,D and try to bundle the links , that won't work :
2 REPLIES 2
RaphaelL
Sorry for the confusion.
I need a EtherChannel between two stacks, and the link of EtherChannel on the different physical switches. I think you answer my question. Thank you!
