Switch Port Profiles
CraigP
I am looking to create a port profile for users, but I want to make it so that we can only have the one user per port. I was looking at using sticky MAC addressing set to 1 but I cannot see how I can do that in a port profile.
Is this possible?
Craig
2 Replies 2
KH
Hey @CraigP
Sticky MAC isn't supported on port profiles. Port Profiles are meant for bulk configurations and something like a unique MAC allow list per port is kind of counter-intuitive to a bulk configuration
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it
CraigP
Hey @KH ,
Thank you for the reply.
