C9300L switch not coming online on dashboard after reboot
Raheel_Islam
Hi, I am facing issue with C9300L switch. Initially Switch was working fine and provisioned on meraki cloud. After reboot the switch is not coming online on meraki Dashboard. Internet is working fine on up-link port.
System LED: Solid Amber
Blue Beacon LED: Solid Blue
I tried to reset switch but after that its stuck in same state.
9 Replies 9
If you plug a console cable in and reboot it, do you see anything useful?
Raheel_Islam
No useful logs after reboot.
Initializing Hardware...
System Bootstrap, Version 17.12.2r, RELEASE SOFTWARE (P)
Compiled Thu 08/31/2023 17:19:41.28 by rel
Current ROMMON image : Primary
Last reset cause : PowerOn
C9300L-48PF-4X platform with 8388608 Kbytes of main memory
boot is : [ boot flash:packages.conf ]
boot: attempting to boot from [flash:packages.conf]
boot: reading file packages.conf
Oct 10 11:47:37.539: %BOOT-3-SYSD_STARTFAIL: R0/0: Failed to launch boot task fpgahelper_autoupgrade.service ( exit-code )
MCU 802.3bt mode supported: False, BT mode: False
Both links down, not waiting for other switches
Switch number is 1
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Cupertino], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.9.3m5, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2024 by Cisco Systems, Inc.
Compiled Wed 17-Jul-24 19:46 by mcpre
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
FIPS: Flash Key Check : Key Not Found, FIPS Mode Not Enabled
cisco C9300L-48PF-4X (X86) processor with 1309176K/6147K bytes of memory.
Processor board ID FVH2819L5WD
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
Base Ethernet MAC Address : 9c:38:18:74:f4:00
Motherboard Assembly Number : 73-102172-06
Motherboard Serial Number : FVH28180U63
Model Revision Number : B0
Motherboard Revision Number : A1
Model Number : C9300L-48PF-4X
System Serial Number : FVH2819L5WD
CLEI Code Number : INMEF00BRE
SETUP: new interface Vlan1 placed in "shutdown" state
If you haven't already, I'd log a ticket.  The line below suggests that the switch has crashed at least at some point:
CAPSUpport
@Raheel_Islam I have the same issue. Did you vere get a resolution?
Raheel_Islam
I am working on this with meraki tech team. I had 4 sessions with them approx 15 hours. i will update here if i got any resolution.
4DCISCO
I HAVE FACING THE SAME ISSUE. DO YOU FIND THE SOLUTION ?
MarkGTG
Did you find a solution?
4DCISCO
Yes. First you create separate VLAN in both firewall and C9300 switch end. Tag the VLAN in any port you want. Connect the cable and wait for 15 to 20 mins.
Main10ence
Hello Everyone,
One thing I can say for rebooting C9300 series switches is to be mindful if the uplink is LACP or not. The reasons can vary for a switch not coming online after a reboot.
If you are able to take a packet capture on the upstream device of the switch, I would do so and look for traffic patterns. For example, are there any packet destined for the Dashboard, and do we have any return traffic from the cloud?
Also, proving the "show tech" can help as well, assuming you can get to the CLI.
.ılı.ılı. Cisco Meraki
Network Support Engineer
"The future favors the bold."
