- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Stack with switches in another room
For a small office of 50 people, we have a server room with 2 MS350-48FP stacked using the stack ports and stack cables at the back of the devices.
The stack is connected to 2 Internet lines and provides Internet access for client machines and Wi-FI APs.
We will rent a new space on the same floor, so we'll have to add two stacked switches (in another comms room that's 20 meters far from the room where the primary stack is) and connect this stack to the primary stack.
I am thinking of stacking the two new switches as a new stack and connecting the two stacks with redundant fiber links.
Is that a good idea? Or should I set up the four switches as a single stack?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In my opinion I would go this way, I think it is more advantageous than having a stack with 4 switches.
In fact, you have to do what you think is most advantageous for you. Everyone has a different opinion.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It's a bit of an 'it depends'.
Personally, I would probably go with 2 separate switch stacks with a port-channel between them as it seems to logically makes more sense in your scenario.
However, if you think you'll have a lot of East<->West traffic between the stacks, where the interconnect might be saturated, then stacking all 4 together might be a better option.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes the port channel is something I wanted to do.
My idea is to set the 2nd stack with stack ports/cables and use the fiber ports on 1 of the 2nd stack's switches, do port channel, and connect to one of the switches on the 1st stack.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You would ideally want to do cross stack port channels. One link from switch 1 and one link from switch 2 in the stack added into a single port channel.
