We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
Hello.
I want to know if Meraki switches are using Spanning Tree path cost long?
Thank you!
Solved! Go to solution.
As mentioned by @Bruce , RSTP is used, and this does use the "long" costs.
Meraki switches do running Spanning Tree Protocol (rapid spanning-tree to be precise), but other than the priority of switches there is nothing more that you can configure. However, they do follow all the normal STP rules that you’d expect.
