- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Show commands
I know that asking this is a risk to be called a dinosaur but, I haven't found anything related to this.
So, is there a way to run show commands in Meraki Switches?
Our team is just "scratching" the Meraki dashboard and today we pass through a problem and we tried to see which VLANs were associated to each port and, the only way that we found was to point with the mouse each port on the switch (in switches overview).
Does anyone know if it is possible?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Ronaldo,
There is not a CLI in the Meraki Devices.
You can check your VLANs associated to each port under Switch > Switch ports. There one of the columns displays the VLANs information, in case you don't have that column, you can add it clicking the "plus" sign at the top right and checking the option.
Let me know if I answered your question.
Regards,
Alejandro.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello Ronaldo,
Regards,
Alejandro.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Well...it doesn't sound as I would like...but I have no choice but to accept
Thank you Alejandro_G
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
On that same page you can also hit the drop down arrow on the search box and put a number in the Vlan box to show all the ports in a given vlan.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you Adam!
