STP port cost
trockid
STP port cost
Is it possible to set a spanning tree port cost on a meraki switch?  I can't find it anywhere...is it yet another super common feature that Meraki doesn't support?
no,
but is it that common with options like stacking, lacp etc?  what are you trying to achieve?
meraki is obviously not a catalyst and you have to design with the functions it support
2 Replies 2
no,
trockid
Thanks for the reply.  To be fair, the only reason I'd like to manipulate the port costs is to force a particular topology in an existing bad design.
I cannot change the overall design at the moment; this would have been a temporary measure.
I can work around this limitation in the meanwhile.
