SNMP restrict SNMP direct polling
Ronny63
Is it possible to restrict SNMP direct polling same as Dashboard access have "IP restrictions list?
//Ronny
Mloraditch
You can restrict MXs WAN SNMP Polling on the firewall page, but otherwise there is not.
2 Replies 2
Mloraditch
RWelch
IP restrictions must be configured to restrict SNMP access to particular IP addresses in the customer environment when using v2c. SNMP versions 1 and 2 send the community string in clear text, so IP restrictions are required to prevent unauthorized SNMP access if the community string is intercepted or learned by another party. They are recommended for v3 but not required.
SNMP Overview and Configuration
