SGT Policy in a single vlan
BoChristensen
Hi there,
I have a test setup, one MS130X switch, in which there are several clients in one VLAN.
They are tagged in SGT with IoT, Clients, and NAS.
Licensing is correct, and enabled.
The clients in "Network Wide -> Clients" are tagged correctly.
if I create a Policy with IoT->IoT: deny (and nothing else), I loose connectivity from a SGT tagged Client to a NAS client (for which, there is no policy).
what dont I get ?
From your description everything is correct, so in this case I believe the best option is to open a support case.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Adaptive_Policy_MS_Co...
BoChristensen
Hi, thanks for the info,
I have read it, but it does not clarify the above example (as I read it anyway)
