SFP-10GB-T Compatibility with MS390-48P switch
DayanandPatil
HI All,
I am looking for SFP 10G Copper module for MS390 series switch. since Meraki is having 10G copper module can SFP-10GB-T modules works?
Please let me know if anyone tested.
Regards,
Dayanand
5 Replies 5
There is nothing on the documentation, so I don't think so.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Plu...
@DayanandPatil it won't be supported, but and Cisco compatible 10G-base-T adapter should work.  We have used them in Catalyst 3850s and I can try one in a 9300 if your like?  We use FS, but others should also work.  I'd avoid Prolabs as I have had issues with their transceivers.  The transceiver usually pretends to be a multimode short range optic as far as the switch can see.
DayanandPatil
Ok. Thank you!! will waiting for your next update on compatibility
mhab12
I would like to know this as well.  Looking to add copper SFPs to our MS390 and noticed the MA-SFP-1GB-TX shows that it is not compatible.  Thanks.
You can check the compatibility here
