Remove DHCP server on MS120
ChaVyzPro
Hi all,
I don't know why but DHCP server on MS120 have been configured all alone ???
after upgrading firmware yesterday ?
How to remove this, the wrong DHCP server Meraki is block and the right one Allowed
But after real reboot clients, they still have the wrong ip address . . .
Kinds regards,
9 Replies 9
I suggest you open a support case.
ChaVyzPro
Hi
ok case already open, still working on it, but no hopes for the moment
BlakeRichardson
Owch... Hopefully the issue hasn't caused too many problems for you.
ChaVyzPro
Hi
a little, but static ip is working . . .  DHCP ip no...
ChaVyzPro
How can I downgrade MS firmware please ?
https://documentation.meraki.com/General_Administration/Firmware_Upgrades/Managing_Firmware_Upgrades
ChaVyzPro
Thanks but ...
I have read and try these two things but not working, or permitting me to do that
Rescheduling or Canceling a Firmware Upgrade
Rolling Back a Recent Firmware Upgrade
ChaVyzPro
Solution ? change switch ...
Kyle_Smith
I would check to make sure the management port is not connected to the network, since it will serve DHCP. This is so that you're able to connect to the local status page without setting a static IP.
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
