Recommendation to connect a Cisco WLC with Lag enabled to a Meraki switch (MS425) in a port channel?
DThomaz
Do you guys have a recommendation to connect a Cisco WLC with Lag enabled to a Meraki switch (MS425) in a port channel?
Thanks,
-Dave
2 REPLIES 2
You can use LACP.
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Link_Aggregation_...
Can't say I have ever bothered using LACP with a WLC.  I normally just configure primary and backup ports.  Keeps everything simple then.
GIdenJoe
@PhilipDAth, an AireOS based Cisco WLC does not have the ability to do LACP, only static LAG is supported.
So basically you cannot do this with a Meraki switch.
You'll only be able to use the classic one port active for an interface and another backup.
