RADIUS Dynamic author list
MartinLL
Hi all,
I'm working on a setup where two Cisco ISE nodes is located behind a load balacer. This is an azure internal load balancer. Traffic from ISE towards NADs retain their original IP address.
Now this causes some issues with COA when i only add the load balancer frontend IP as a RADIUS server. To get coa to work i need to add the load balancer front end as well as the individual node IPs. This fills up the meraki maximum of 3 RADIUS servers leaving no space for expansion.
Is there any way to add the node IPs as just dynamic authors like on IOS-XE?
MLL
Unfortunately, Meraki does not currently support adding dynamic authorization clients (DA clients) separately from RADIUS servers like IOS-XE does. In Meraki, CoA  support is tied directly to the configured RADIUS servers.
MR Meraki RADIUS 2.0 - Cisco Meraki Documentation
MS Switch Access Policies (802.1X) - Cisco Meraki Documentation
Change of Authorization with RADIUS (CoA) on MS Switches - Cisco Meraki Documentation
2 Replies 2
MartinLL
Shame. Hope this is something the team plans to address.
MLL
