Question about Vendor MAC based VLAN Access
JoachimGebhardt
Hey,
for some project, we try to figure out, how to do a Vendor MAC based VLAN Access with Meraki MS best.
Examples:
All Printers - VLAN 100
Vendor X - MAC 00:01:AA
Vendor Y - MAC 03:05:AA
All Phones - VLAN 200
We already did some Test with NPS Radius, Packetfence but we are not happy at all.
Maybe you have some ideas for us.
Thanks in Advance
CMNA, CMSS
5 Replies 5
The best tool for your case is Cico ISE.
https://community.cisco.com/t5/security-knowledge-base/how-to-integrate-meraki-networks-with-ise/ta-...
https://community.cisco.com/t5/security-knowledge-base/dynamic-attribute-with-ise-mac-address-matchi...
KarstenI
+1 for Cisco ISE, MAC-based access is easy and the ISE will make it much easier than for example NPS to move to 802.1X later.
JoachimGebhardt
OK, thanks for your replies.
As I figured out, we will need ISE Advantage Licenses for profiling. Am I right?
CMNA, CMSS
KarstenI
Yes, Advantage or "better" is needed for profiling. But only for the devices that get their authorisation by elements from profiling.
KarstenI
But you only need profiling if you want the system to detect the type of device. If you are willing to classify your MAC-addresses into groups manually (or by import from a CSV where the mapping is available), the Essentials-license is enough. And that license is quite cheap.
