Meraki as Core - Crestron NVX
Sawan
Hi
We have a network where we have the MS425-32 as a core. There is lot of Video Over IP multicast traffic from Crestron NVX in 5 diff switches in the property. The Crestron NVX requires IGMPv2 Snooping enabled, querier enabled and fast leave enabled.
The other switches are from Pep link, and have IGMP v2 enabled with querier and fast leave - it works fine on its own.
The moment I connect the SFP port from the switch with AV over IP traffic, MS425-32 gets flooded and offline from cloud.
Any tips to configure it to work with Crestron NVX.
There are 3 VLAN, the default VLAN 1 has all the Multicast traffic. Ive setup the switch :
Switch VLAN Name Subnet IP DHCP Settings OSPF Routing Multicast Routing
Cam1MA10.0.8.0/2210.0.10.1OffDisabledIGMP snooping querier
Thank you
6 Replies 6
What version are you running? Can you share the port configuration? Have you checked the logs?
Sawan
Hi
Thanks for the prompt reply!
Im running MS 14.33. Didn't check the logs - we reset the device and starting from scratch.
Please see the screenshots of port config.
Have you tried disabling It?
Sawan
Its disabled.
We are not doing Multicast Routing between VLANs, just IGMP snooping and querier is required by the devices which are connected on VLAN1
Have you tried It?
Recommendations when using Multicast Routing
Simple Service Discovery Protocol (SSDP)
It is strongly recommended to block SSDP (Simple Service Discovery Protocol) traffic when Multicast Routing is enabled.
SSDP traffic (UDP multicast to 239.255.255.250) is commonly generated by Windows clients to discover or announce network services. The mechanism used by SSDP for discovery and advertisements imposes additional burden on the multicast routing process as it needs to track each client in the routing table. In addition, the high frequency and volume of SSDP messages can cause frequent updates on the multicast routing process for a non-critical service.
There are a couple of options to block/disable SSDP:
1) Apply an ACL rule by navigating to Switch > ACL
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Multicast_Routing_Overview
It may be your IGMP querier configuration.
Check out this excellent explanation and see if that gives you some ideas:
https://community.meraki.com/t5/Switching/Multicast-Basic-s/m-p/25867/highlight/true#M2125
