Problems configuring the ports of my switch
LopezJ
I'm trying to change the name or ip of the ports of a switch, but I get the following error
I have even added another switch to the network and the same thing happens, but if I add this switch to another network it does not happen.
Do you know what can happen?
RWelch
Although I am not 100% certain, it appears that you are attempting to change VLAN Profile name (iname) which is giving the error as already existing or trying to add it again.
VLAN Profiles
Can you share the screenshot of what exactly you are trying to change?
RWelch
VLAN Profiles
LopezJ
It seems to be that I had two VLAN Profile configured by default and that is what was causing the problem 🙂
Thank you very much
Meraki switch ports don't have an IP address, so I'm not sure what change you are attempting.
If you are trying to change multiple things at once, try making one change at a time until you find out which change is casuing the issue.
