Problem discovering printers accross different VLAN
Massimo
I have VLAN 1 for DATA and in this VLAN i connected the printers.
I have VLAN 80 for Wireless and in this VLAN i connect an IPAD
Discovery printers using IPAD didn't find any printers.
If i connect the IPAD to VLAN1 all working fine
i tried also to enable bonjour gateway but still not works.
Firewall is MX and all switch and AP are Meraki.
2 Replies 2
Bonjour (what Apple uses) does not work across subnets.  So you have to use a Bonjour gateway.
If you have MR, read this:
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/Bonjour_Forwarding
https://documentation.meraki.com/MX/Other_Topics/Configuring_Bonjour_forwarding_for_the_MX_Security_...
Note that the devices you want to access (aka the printers) can't usually be on the native VLAN, aka VLAN1.  You normally have to put them on another VLAN.
@Massimo  as mentioned check your bonjour gateway settings, we use this ourselves and it does work. If you can get it to work please post a screenshot of your settings.
