Power cable to UPS - MS250 and MS390
Baka
Been trying to find this information  for quite a while , but as Meraki only do Power cables to the Mains , I am in need for some Switch to Ups cables.   and  I've bouht some IEC 13 to 14 cables   and sent them to instalatio site..  but been told they don't fit  as thre's a small notch in it .
I can't for the life of me figure out what cables do I need to buy... and  to be 100% sure they will work..   any help would be much appreciated.
Thank oyu
@Baka you need cables with the C15 connector (the one with the notch cut out of it) - it is a high temperature connector and will have a cable rated for a higher temperature connected to it.  You can easily get C15 to C14 cables.
1 Reply 1
