Port channel using MS warm spare
Luffy
Hi guys,
I have a question about warm spare issue.
This is a sample diagram.
ISP Modem--MX1--(Warm Spare)--MX2--MS1--(Warm Spare)--MS2--MR1--MR2
I want to set redundancy setting for safe operation.
Q1. In case of sample diagram, does MS device need to set port channel setting for MX1 and MX2 port ?
Q2. Please confirm whether my understanding of connecting physical cable is correct or not as below.
ISP Modem---MX1
ISP Modem---MX2
MX1---MX2(Warm Spare)
MX1---MS1
MX1---MS2
MX2---MS1
MX2---MS2
MS1---MS2(Warm Spare)
MS1---AP1
MS2---AP2
Thank you,
The MX series does not support part-channelling - so no, don't configure a port channel to them.
Yes that cabling seems fine.  Are you going to stack your two MS together using the stacking ports - or keep them separate?
4 REPLIES 4
Thank you for your answer.
In my understanding to set MS redundancy, there are two options.
one is just warm spare between two MS device without any setting.
another is stacking setting using stacking cable between two MS device.
In this case just warm spare without stacking cable.
Does it work well ?
There are benefits both ways, but I generally prefer stacking as it is easier.  You have a single instance of spanning tree.  You have a single config which either stack member can take over.
I understand what you said.
Thank you for your answer 🙂
