Port Security in MS Switches
Mahjouboi
we recently started our journey in Meraki, I'm looking for port security same to what we have in Catalyst switches in order to allow only 2 devices to connect in switch port (laptop and IP phone).
please your advice if this possible in MS switches.
Thanks,
1 Reply 1
Brash
It kind of depends how you had port security set up previously.
Meraki supports both explicit MAC address whitelisting and sticky MAC address whitelisting.
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Ports#Port_configuration
It doesn't however support a MAC address maximum where (for example) you enforce only 1 MAC address to be allowed on the port at any one time, but that MAC address can change. The equivalent of
Switch(config-if)#switchport port-security maximum 1
