One of connection would be blocked in Meraki switch?
Merakibgp
Hi there are three meraki switches A, B and C with full connection for each one. My question is whether there is the same spanning tree mechanism as Cisco general switch? for example, If switch A is root,  and port at switch B connected to switch A is designate port, the port at switch C connected to A would be blocked?  Thank you
4 REPLIES 4
Thank you so much for your reply. How can we know which switch is root?
You can statically configure it (info in the same link I published above).
If you look at a switch in the dashboard it will tell you that it is either the root, or which port the root is connected to.  Some examples are below.
Excellent explanation!
