New beta MS14.21 firmware, stability and 390 fixes
Switch firmware versions MS 14.21 changelog
Alerts
MS390 upgrades from MS 14.19 or later will result in minimal impact to client traffic
Branch additions
SNMP support for MS390s
RADIUS accounting support for MS390s
Alternate Management Interface support for MS210/MS225/MS250/MS350/MS355/MS410/MS425/MS450 series switches
QoS support for MS390s
CoA support for MS390s
STP anomaly detection events for non-MS390 series switches
Adaptive policy support for MS390 series switches
SecureConnect support for MS210/MS225/MS250/MS350/MS355/MS410/MS425/MS450 series switches
Bug fixes
Changing a MS390's port between access and trunk could result in the updated configuration not being saved. A reboot was required for the new configuration to be saved
OSPF fails to form adjacencies when more than 164 SVIs are configured on a switch
MS22/42/220/320 series switches would experience a reboot if the network was configured to use Group Policy ACL
An event log was added for client authentication timeouts during EAP authentication
MS390 series switches would incorrectly set the NAS-IP to 1.1.3.1 in RADIUS packets
Known issues
In rare instances, a stack member may go offline until rebooted (present since MS 12)
In rare instances, MS390s can lose connectivity to dashboard and require a manual reboot to recover. Control plane traffic is not impacted when this issue is encountered.
In rare instances, non-390 stack members will reboot (present since 12.29+)
Due to FEC incompatibility between MS450 and Cisco Fabric Interconnect 6454, 100GbE links do not establish
MS120s switchports with MAB authentication may randomly deauthenticate clients. In order to resume client authentication on that port, a switch reboot is required (present since MS 12)
Client connection tool show "NaN%" values between an MR and upstream MS
MS120s on rare occasions will reboot (present since MS 11)
MS355 stacks upon reboot have a chance that the uplink port will go into STP blocking state (predates MS 12)
L3 stacks will experience packet loss after an L3 configuration change is made. In order to restore complete stack stability, a reboot may be required.
Stackpower is not enabled on MS390s by default
Broadcast types of traffic can leak into the Guest VLAN if a port that fails authentication has a Voice VLAN configured, and dashboard has a Guest VLAN defined (present since MS 11)
Links being established on a MS120 can result in neighboring ports to flap (present since MS 11)
The UI for MS390s may incorrectly aggregate ethernet ports when SFP ports were selected
MS120s with multiple access policies enabled may reboot when port changes are made
The UI for MS390 series switches will report the old STP bridge information until rebooted
MS390 port traffic in the UI on occasion can show negative traffic for a client
The traceroute live tool fails to run
The UI will show clients connected to MS390 access ports as being on the "native" VLAN
Stackings running PIM may encounter synchronization issues which can result in some receivers being unable to receive certain streams
MS390s acting as STP root incorrectly reports "00:00:00:00:00:00 (priority 0)" on the switch details page (present since MS 12)
Enabling Combined Power on MS350/355 switches results in events being logged once per minute (present since MS 11)
Networks containing a high number of switches may encounter issues saving changes on the Switch Settings page
MS220 and MS320 switches may randomly reboot in large L2 domains (present since MS 11)
The list of switches to clone from fails to load when cloning a switch in an organization with a large number of switches and networks
Switchport tags cannot be removed if they are added after a port profile is attached to the switch
In rare instances, when a stack reboots, ports may come up as "LACP blocked state", even if LACP is not configured (present since MS 10)
MS390 stacks on rare occasions will require a manual reboot after the upgrade has completed
MS390 series switches do not support SM sentry
MS390 series switches do not support Syslog
MS390 series switches do not support IPv6 connectivity to dashboard
MS390 series switches do not support Meraki authentication
MS390 series switches do not support URL redirection
MS390 series switches do not support MAC whitelists
MS390 series switches do not support loop detection
MS390 series switches do not support warm spare/VRRP
MS390 series switches do not support UDLD
MS390 series switches do not support MAC flap detection
MS350-24X and MS355 series switches do not negotiate UPoE over LLDP correctly (predates MS 10)
Rebooting any MS390 stack member via the UI will result in the entire stack rebooting
Also, I think it woul dbe helpful to group issues/additions by model... perhaps those that affect multiple models at the top and then in alphanumeric order issues/fixes that affect only a single model.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_54e23598712fee","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_54e23598712fee_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_54e23598712fee_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_54e23598712fee_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_54e2358e37583b","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
