New VLAN on MS425 core
JoshBoldt
If I add a new VLAN under Switching > Routing & DHCP with DHCP > Relay and OSFP > Enabled and then add it to the 'Allowed VLANs' on all the switch ports on my core that need it, it should just work right?  Is there anything else I need to do to make it show up on the network? I feel like I am missing something.
Yes, it's supposed to work.
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Layer_3_Switching_and_Routing
That should create an interface on the particular VLAN of that switch indeed.  If it is the first then it should have also asked you for a default route.  What isn't working?
  • Interface routing
  • DHCP relay
  • OSPF membership
JoshBoldt
Thanks. I'll have to ask exactly what the problem is. They just told me they can't get to the internet.
