New MS 14.20 firmware
Switch firmware versions MS 14.20 changelog
Alerts
  • Upgrades from MS 14.20 or later will result in minimal impact to client traffic
Branch additions
  • SNMP support for MS390s
  • RADIUS accounting support for MS390s
  • Alternate Management Interface support for MS210/MS225/MS250/MS350/MS355/MS410/MS425/MS450 series switches
  • QoS support for MS390s
  • CoA support for MS390s
  • STP anomaly detection events for non-MS390 series switches
  • Adaptive policy support for MS390 series switches
  • SecureConnect support for MS210/MS225/MS250/MS350/MS355/MS410/MS425/MS450 series switches
Bug fixes
  • MS390s that had a voice VLAN on access ports in a link aggregation would lose the port's VLAN configuration and default to VLAN 1 after a reboot
  • L3 switches with a DHCP relay configured could sporadically drop DHCP Offers (present since 12.11)
Known issues
  • In rare instances, a stack member may go offline until rebooted (present since MS 12)
  • In rare instances, MS390s can lose connectivity to dashboard and require a manual reboot to recover. Control plane traffic is not impacted when this issue is encountered.
  • OSPF fails to form adjacencies when more than 164 SVIs are configured on a switch
  • In rare instances, non-390 stack members will reboot (present since 12.29+)
  • Due to FEC incompatibility between MS450 and Cisco Fabric Interconnect 6454, 100GbE links do not establish
  • MS120s switchports with MAB authentication may randomly deauthenticate clients. In order to resume client authentication on that port, a switch reboot is required (present since MS 12)
  • Client connection tool show "NaN%" values between an MR and upstream MS
  • MS120s on rare occasions will reboot (present since MS 11)
  • MS355 stacks upon reboot have a chance that the uplink port will go into STP blocking state (predates MS 12)
  • L3 stacks will experience packet loss after an L3 configuration change is made. In order to restore complete stack stability, a reboot may be required.
  • Stackpower is not enabled on MS390s by default
  • Broadcast types of traffic can leak into the Guest VLAN if a port that fails authentication has a Voice VLAN configured, and dashboard has a Guest VLAN defined (present since MS 11)
  • Links being established on a MS120 can result in neighboring ports to flap (present since MS 11)
  • The UI for MS390s may incorrectly aggregate ethernet ports when SFP ports were selected
  • MS120s with multiple access policies enabled may reboot when port changes are made
  • MS390 port traffic in the UI on occasion can show negative traffic for a client
  • The traceroute live tool fails to run
  • The UI will show clients connected to MS390 access ports as being on the "native" VLAN
  • Stackings running PIM may encounter synchronization issues which can result in some receivers being unable to receive certain streams
  • MS390s acting as STP root incorrectly reports "00:00:00:00:00:00 (priority 0)" on the switch details page (present since MS 12)
  • Enabling Combined Power on MS350/355 switches results in events being logged once per minute (present since MS 11)
  • Networks containing a high number of switches may encounter issues saving changes on the Switch Settings page
  • MS220 and MS320 switches may randomly reboot in large L2 domains (present since MS 11)
  • The list of switches to clone from fails to load when cloning a switch in an organization with a large number of switches and networks
  • Switchport tags cannot be removed if they are added after a port profile is attached to the switch
  • In rare instances, when a stack reboots, ports may come up as "LACP blocked state", even if LACP is not configured (present since MS 10)
  • MS390 stacks on rare occasions will require a manual reboot after the upgrade has completed
  • MS390 series switches do not support SM sentry
  • MS390 series switches do not support Syslog
  • MS390 series switches do not support IPv6 connectivity to dashboard
  • MS390 series switches do not support Meraki authentication
  • MS390 series switches do not support URL redirection
  • MS390 series switches do not support MAC whitelists
  • MS390 series switches do not support loop detection
  • MS390 series switches do not support warm spare/VRRP
  • MS390 series switches do not support UDLD
  • MS390 series switches do not support MAC flap detection
  • MS350-24X and MS355 series switches do not negotiate UPoE over LLDP correctly (predates MS 10)
  • Rebooting any MS390 stack member via the UI will result in the entire stack rebooting
  • MS390 upgrades from 14.20 or later will result in minimal impact to client traffic
1 Reply 1
rhbirkelund
The MS390 really does feel like buying the cat in the bag.
