Network Standards of MS120 and MS225
josecarlossml
I am studying the buy some MS120 and MS225. I am curious about some standards that I did not find in datasheet. Can someone help me with this?
IEEE 802.1s
IEEE 802.3x
IEEE 802.3
IEEE 802.3u
IEEE 802.3ab
IEEE 802.3z
IEEE 802.3az
IEEE 802.1ax
For example, datasheet says that the switch has flow control but does not show anything about 802.3.
1 Reply 1
jdsilva
IEEE 802.1s - This is MST, not supported. Meraki switches only do 802.1w (RSTP).
IEEE 802.3x - This is Flow Control. I do not believe this is supported (I've never seen it anyway). Check with your Meraki rep.
IEEE 802.3 - This is Ethernet. If it's not supported then Meraki has some serious issues...
IEEE 802.3u - This is 100Base-TX. Supported.
IEEE 802.3ab - This is 1000Base-T. Supported.
IEEE 802.3z - This is 1000Base-X. Supported, but check the compatible SFP list.
IEEE 802.3az - This is EEE. I'm unsure if this is supported... I can't find anything that says either way. Check with your Meraki rep.
IEEE 802.1ax - This is 802.3ad AKA LACP. Supported.
