- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Multiple Public Switches on same ISP subnet Static IPs - No Connection
All,
I installed a Miraki switch on one of my ISP public IPs (1 of 5). I have another router for different network on IP 2 of 5. The Miraki VPN won't allow from the other router traffic.
I resolved this years ago with a Sophos switch, but do not see the same option in Miraki.
How do I make it so the other routers on the same block of static IPs can talk to each other?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you want to route traffic internally between the two devices then they'll need a LAN connection between them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
two different buildings so that is not possible. two routers under the same ISP subnet have to be directly cabled? they are both connected to the perspective internet behind the same ISP router\switch\modem.
