Ms425-16 Pair - Stack or warm spare
Trixxz
Hi all
We have a pair of 425-16s that we would like to use to replace an existing single core switch. Can anyone give me any tips on whether to stack these 2 or use warm spare. On both if you could detail cabling examples that would be great.
Am I correct in thinking with Warm spare I would need uplinks into both switches from each distribution switch?
When using the Warm Spare setup, you would need uplinks into both switches from each distribution switch.
MS Warm Spare (VRRP) Overview - Cisco Meraki Documentation
Switch Stacks - Cisco Meraki Documentation
MS425 Series Installation Guide - Cisco Meraki Documentation
DarrenOC
Hi @Trixxz , I would keep the solution simple and just stack the ms pair.
For resilient links I would also patch each distribution switch into each core switch.
Prestont
the main difference I find between for a warm spare or stacking would be how you want them to reboot on a firmware update.
On a switch stack the switches will all reboot at once.
while with a warm spare I think you can do the firmware updates with a stagged update, so that during the update you can still have a switch up and working. Less down time.
I have some MS425 on my ESXI Clusters and I like having them not stacked so I can have no downtime during a switch firmware update. you just have to make sure you have links for both switches to work when the other is offline.
Brash
As stated above, stacking is simple and will make your life easier.
The downside of which is that during a firmware upgrade, the stack reboots as a whole resulting in a network outage for connected devices.
If that's feasible for your business to manage then IMO, stacking would be the way to go.
