Meraki switches cleaning
Grégory
We will provide a IP network into a building with meraki switches. The owner of the building want us to open the switches to clean the dust.
Is it allowed by meraki to do such thing ? Or it will break the warranty ?
I didn't find any documentation about that specific subject or how it should be opened safely.
Thank you very much,
Grégory
Brash
I've honestly never tried to open up a Meraki switch. Assuming you can, I imagine it runs along the same lines as most enterprise gear, in that you take on all risk of any damage during the process.
In my opinion, compressed air and a vacuum to clean any dust out of the ports and vents should be plenty adequate. You shouldn't need to open up the entire switch.
2 Replies 2
Brash
Grégory
Thank you very much.
We will try to tell that to the client.
Have a nice day !
