Meraki licensing
Amit_pal
Meraki licensing
I have a question regarding meraki Licensing .
In our Organisation we have MR,MX and MS products and we are using co-termination licensing model.
We have meraki switches which were bought with 8 years licence and since we were using co-termination licensing model , the license of other meraki products(MX,MR) also got extended .
Now our plan is to replace MS with Cat 9300 and decom MS switches,i'm wondering what will happen to MS licenses , will it be taken down and eventually will effect the other products(MX & MR) license date ?
Brash
The MS licenses will remain applied to your org and will continue adding towards your co-term expiration date.
Are you using the 9300 switches in Meraki mode, or Catalyst mode?  If Meraki then you can convert the licensing with support.  If Catalyst then I think you will just waste the rest of the license.
Amit_pal
We are not onboarding Catalyst to meraki..
Ah that means Decom will effect license of other devices as well ?
Brash
