Meraki core switch fallback from Static IP to DHCP
Mon19
The core switch is obtaining its management IP via DHCP instead of the previously statically assigned
Probably when you make the change, it can't communicate with the Meraki cloud again, so the configuration is rolled back, which is the expected behavior.
How are you making this change?
This will be exactly it.
RWelch
You can check Organization > Monitor > Change Log for any recent changes to the switch's management interface - not sure if you were wanting to find out the "why" part of the equation or what caused this to occur.
This normally happens when there have been manual configuration changes (e.g., an admin set the switch to use DHCP for management), or a configuration rollback, or firmware upgrade or device reboot that did not regain the static IP setting.
Assigning a Static IP Address
BlakeRichardson
Is the IP you are assigning on the same VLAN and if not are you setting the VLAN ID at the same time?
