Meraki Switch MX65
abdikani
Meraki Switch MX65
Hi all
I have received a Meraki switch mx65 on the first time and I want to add my existing network, but I have some issues like only wife networking are working but ethernet network ar not working, the network I use Uniffi equipment (Switch, USG router, and access points) so I have tried to remove Unifi switch and put the Meraki one, please let me know if anyone has that experience.
Abdikani
8 Replies 8
rwiesmann
Hi Abdikani,
the MX65 is a Security and SD-WAN Gateway and not a switch.
Check out the following link...you also can find deployment guides on this link
https://documentation.meraki.com/MX
hope this helps
roger
Thanks a lot for the prompt reply .
Sorry, Yes it's a Security and SD-WAN Gateway I want to use as a security appliance, so now my network contains, internet Antenna which connects the unify USG router, and the router connects to unify switch then from the switch access points and ethernet cables, so where should I put MX65 as its already configured by the organization, should I remove unify USG router.
Not quite sure what you want to achive/replace.
As I understand your setup...
Internet Antenna
then
Meraki MX
then
Switch
then
AP
But I am not sure if you need the USG to terminate the Internet Antenna...if so...you could place the MX just behind the USG Router.
So it's depending what you would like to achive and which devices you need for certain functions.
rgds
roger
I just want to remove USG and put Meraki MX , I did it, and its working, but MX65 providing a different IP address so I want to change this IP address and make like the one I was using in the USG , but when I try to change IP , a get this error
  • The local subnet cannot overlap with the client VPN subnet.
Change the client VPN subnet that you have configure to something else.
I had changed the client VPN  Ip and subnet but I am getting this error
  • MX IP   12.0.0.12      Subnet 12.0.0.1/24
so what am I suppose to do as this IP and subnet are the ones that I used my USG router which I removed from the network and I put the MX65 instead?
KarstenI
Hopefully this is not your real IP ...
For an IP of 12.0.0.12, the subnet has to be 12.0.0.0/24. But the relevant change is done unter
Security & SD-WAN -> Client-VPN -> Subnet.
This Subnet is not allowed to overlap with your MX subnet.
@abdikani You are aware that the 12. subnets are public IP addresses and not intended for private use?  Internal networks usually use private ranges listed below:
10.0.0.0/8
172.16.0.0/16 to 172.31.0.0/16
192.168.0.0/24 to 192.168.254.0/24
Any of the above can be subnetted to smaller ranges.
