Meraki MX-68 Communicate between VLANS
cmal00
I'm new with Meraki and using MXs. I was trying to have two different VLANS to be able to communicate between each other. I have a wireless VLAN 5  (laptops) that needs to go to a wired printer. (VLAN 10). Can't find where to configure that if possible.
7 Replies 7
Ryan_Miles
Meraki Employee All-Star
Traffic should route between VLANs by default. There are no deny firewall rules by default (aside from outside to inside.)
MartinLL
It's routed by default. If you go to Security & SD-WAN > Firewall you can see the rule set controlling inter-VLAN communication as well as LAN to WAN. The default firewall rule is permit any. So as @Ryan_Miles states, it will just work by default.
MLL
RWelch
You can go to Security & SD-WAN > Configure > Firewall under Bonjour Forwarding and add services pertinent to your setup/configuration.
cmal00
 I had it Deny. I will test tomorrow at work. I'll let you know if it worked.
cmal00
I'm able to ping now the other device on the other VLAN, looks like it's working...Thanks a bunch!
Have you managed to configure the two VLANs on the MX - or is that the bit you are getting stuck on?
If you have managed to configure the two VLANS - are machines on both able to talk to the Internet ok?
