Meraki MS250 Uplink support for 1GbE
willscotty2012
Hi All,
I have checked the datasheet for the Meraki MS250 switch and it states that all models provide 4 x 10GbE SFP+ uplink ports, however, the documentation does not state if the uplink ports also support 1GbE? I need to install a couple of these switches with 1GbE SX uplinks initially before switching to 10GbE SR.
Many thanks
yes you can use SFP in SFP+ slots
look for Compatible Accessories
 https://meraki.cisco.com/products/switches/ms250-48
2 Replies 2
@ww is correct, you can just plug in a Gigabit SFP.
