Hello Team,
Is that possible to deliver dynamic voice vlans to Meraki from ISE as we can do with the data vlan?
We have an environment with two voice vlans (vlan A and vlan B). Vlan A is static configured in the switch port as voice vlan.
When I connect an IP Phone that needs to be in the vlan B, I can see in the event log a radius response sending the vlan B to the switch, but actually the vlan override didn't occurs (the client keep in the vlan A).
In the ISE side, all the process is okay. We have one authz profile for each vlan with the flag (enable voice vlan domain) checked.
The PC connected behind the IP Phone is working okay, with the data vlan changed according to the AD Group.
I have saw some posts in the community indicating that dynamic voice vlan didn't work in Meraki. Did I understand correct?
If so, what is the alternative to automatically delivery the differents voice vlans? Because statically assign one of this two vlans in the ports is not a good option, because the users is moving frequently in the environment.
Thanks.
