Meraki MS - LACP
Pavan_Pawar
Meraki MS - LACP
Hello Experts,
I'm configuring the LACP on the MS switch, I see we can add interfaces to the port channel from different switches, so it is like VPC or MLAG in Meraki MS?
but the document says aggregator can be done on the same switch interfaces.
"Link Aggregation
The MS switches support Link Aggregation (LACP) groups of up to 8 ports on the same switch or physical stack."
-Pavan
2 Replies 2
Meraki switches do not have VPC or MLAG.
They work like any other switch, in Stack or standalone. So the configuration is exactly as the documentation says.
Brash
To clarify this a bit further, you can have a LAG of ports that span across different switches within a physical stack.
