Meraki MS - CS 15.21.1 to CS 17.2.2
HumbleNetworkGu
Hi All,
Just want to know, in midst of planning to upgrade my switch firmware from the subject. I read that 17.1.3.1 already fixed an issue regarding (Fixed an issue causing switches to restart after stack failovers) is this correct. Can someone verify this.
Thanks.
Mloraditch
The best way to verify if a specific bug is fixed is contact support. The release notes certainly indicate such a bug has been fixed, but since Meraki doesn't  use bug ids universally, we aren't going to have a way to check if your specific problem has been fixed, especially considering how old your firmware is and how many changes have been made from then until now. Support does have this info and can let you know.
RWelch
Are you referring to 17.15.3.1?
CS firmware versions IOS XE 17.15.3.1
HumbleNetworkGu
No, because the switch firmware suggested until 17.2.2. Along i read to jump the firmware. I notice 17.1.3.1 already fix the switch restart after stack failover. Need to verify. This issue haunting me almost 2 years already.
Mloraditch
