Many-to-Many MS Port Mirroring Solutions
KRobert
Hello MS Community! We recently partnered with a Security MSP and the have supplied us with an appliance that needs to sniff our traffic appliances connected to MS250 switches. During installation, we discovered the Meraki switches only support 1-to-1 or 1-to-many port mirroring switchports. Typically this MSP appliance would tap into multiple interfaces on a Cisco switch and contain specific VLAN traffic per mirrored port.
Example includes:
1-to-1 to port mirror for LAN traffic.
1-to-1 to port mirror for WAN traffic.
1-to-1 to port mirror for DMZ traffic.
In this example, three sniffing ports on the appliance would connect to three mirror destination ports, which would be mirroring 3 source ports.
Based on Meraki's documentation, this isn't possible, but I was wondering if anyone has had support be able to change this to support multiple 1-to-1 port mirrors or if you had to come up with a solution to workaround the issue. Any information would be helpful.
Thank you,
CMNO, CCNA R+S
Use a trunk port to the MX for as much as possible, and the mirror that to the device.
KRobert
We have two trunk ports on our MX, one for the LAN and one for the DMZs. So this allows us to see the LAN and I could see the appliance viewing the DMZs as well. The problem we are having is with the combo of needing the LAN/WAN together and pointing it back to the single sniff port. Ideally we need two sniff ports on the MS appliance.
CMNO, CCNA R+S
KarstenI
I assume you need to buy a network-Tap.
