Manually Set PoE+ Power on Meraki Switch
Markhaught
I have an an application that requires a PoE+ port to be set statically for maximum power output and ignore CDP or LLDP messages.   On Cisco Catalyst switches this can be done using PoE port static mode but I don’t see anything in the Meraki dashboard other than PoE enable/disable.   Can Meraki switch ports be set like this?
Thanks…Mark
Not to the best of my knowledge.  PoE must be negotiated.
Markhaught
Thank you!
Not at this moment.
Markhaught
Thank you!!
