Following the documentation's best practice for the Layer 3 switch topology... if you have a 2nd L3 switch downstream in another building, would it be best to have that 2nd L3 MS also linked via an Access port using another MgmtTransit VLAN?
I know you cannot use the L3 interface for management's connectivity.
 https://documentation.meraki.com/Architectures_and_Best_Practices/Recommended_Topologies/MX_and_MS_...
Building A
MX Addressing & VLAN Configuration
Access VLAN 50: 192.168.50.0/29 (MXTransit)
MX IP: 192.168.50.1
Static Routes
Route 1: 192.168.32.0/24 (MgmtTransit)
Next Hop IP: 192.168.50.2
Route 2: 192.168.22.0/24 (Servers)
Route 3: 192.168.12.0/29 (VPN Concentrator)
Route 4: 10.0.42.0/24 (Clients)
Route 5: 10.0.43.0/24 (Voice)
Route 6: 172.16.1.0/24 (Guest)
MX Management IP: (public IP)
Building A L3 MS Routing Configuration
Access VLAN 1 : 192.168.32.0/24 (MgmtTransit)
MS IP : 192.168.32.1
VLAN 2 : 192.168.22.0/24 (Servers)
MS IP : 192.168.22.1
VLAN 3 : 192.168.12.0/29 (VPN Concentrator)
MS IP : 192.168.12.1
MS IP: 192.168.50.2
Static Routes
Route 1: 10.0.42.0/24 (Clients)
Next Hop IP: 192.168.32.2
Route 2: 10.0.43.0/24 (Voice)
Route 3: 172.16.1.0/24 (Guest)
Route 4: 10.100.0.0/16 (Branches S2S)
Next Hop IP: 192.168.12.6 VPN Concentrator VIP
Default Route: 0.0.0.0/0
Next Hop IP: 192.168.50.1
MS Management IPs: 192.168.50.3-4 (using MX gateway .1)
Building B - FiberToBuildingA - Access VLAN 1
Building B L3 MS Routing Configuration
MS IP : 192.168.32.2
VLAN 42 : 10.0.42.0/24 (Clients)
MS IP : 10.0.42.1
VLAN 43 : 10.0.43.0/24 (Voice)
MS IP : 10.0.43.1
VLAN 172: 172.16.1.0/24 (Guest)
MS IP: 172.16.1.1
Next Hop IP: 192.168.32.1
Untagged VLAN 1 Management IPs: 192.168.32.3-20 (using upstream L3 MS for gateway .1)
