Add Meraki Switches to an existing template
jwatts
Not sure how to word the question. We currently have Meraki MR's that are under a template that is "Network type" wireless. We have purchased Meraki MS switches. What is the easiest way to set this up to be managed per network. I currently have 29 networks under the current template. I really don't want to have separate networks for wireless and switches. I would like to be able to manage APs and switches per location. Thanks!
Check it out:
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
It is a real pain - you have to convert the existing template to a "combined" template.
This guide shows you how to do this process:
https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_...
jwatts
Thanks for the replies. I believe I understand it now.
